jblake240's avatar
jblake240
Ram 3500 vs 3500 dully four wheel.
I WILL BE Travelling THE USA AS A FULL TIMER AND WILL BE BUYING A NEW RAM 3500 DIESEL. DON’T WANT A DULLY. TOLD THAT THE NEW 3500 NON DULLY WILL BE ALL I WILL NEED AND WILL BE MORE THAN HAPPY WITH THE TOWING AND
PERFORMANCE ABILITY.
NEED FEED BACK PRO AND CON.
  • mrkoje wrote:
    Stability with the DRW and maneuverability with the SRW. The RAM 3500 SRW has a payload cap I believe just a tad north of 4k pounds while the DWR is in the 7k range somewhere. If you are full timing the decision might lie with then FW that you choose.
    . Take care when basing your decision on these ratings. These are for a bare/no options truck. A Ram with all options could easily reduce these payload ratings up to 1000 lbs...
  • What RV will you be pulling? Answer that and you will get a better answer.
    I have been driving a 3500 Dually for almost 3 years. It's a great towing rig would not go back to a SRW.
  • It will depend on the hitch weight of the fiver. I opted for a smaller fiver so that I could run with a SRW.
    Mike
  • rhagfo's avatar
    rhagfo
    Explorer III
    If it were me dually for sure!
    You would learn to deal with the size.
  • Dually or Single....all has to do with what you are going to hook to it.
    i.e. weight of trailer. It's all about payload.
  • Stability with the DRW and maneuverability with the SRW. The RAM 3500 SRW has a payload cap I believe just a tad north of 4k pounds while the DWR is in the 7k range somewhere. If you are full timing the decision might lie with then FW that you choose.
