jhlee's avatar
jhlee
Ramp door replace with a larger door
My current RV is a KZ 37k. I work remote out of this when we travel and attend our local chapter monthly rallies. I constructed a desk top that folds down flush against a side wall when I do not need the office and we use the ramp as a patio deck. We do not haul any toys. I am looking for something to replace this with and the nearest we can find that my wife and I have on our want list is the Keystone Raptor 3602RL for many reasons. The downside is the ramp door is too narrow as we like to sit out and it is a nice area for the dogs with the railings installed. My question is can the ramp door be replaced with a full width door like most toy hauler ramps? Obviously I am looking for a business that performs body work and customization to RVs that would perform the work. We are in Texas but we travel north to get out of the heat during summer months.
One thought I had was a ramp extension that folds out sideways once the ramp door is horizontal. This options advantage is no structural changes would have to be performed to fit a full size ramp door. My wife would like a full view though. Again just thinking of all possibilities, reasonable options.
Thank you for any suggestions you have.
  • jhlee wrote:
    Carringb - what make an model is this so I can lookup more information? It looks very interesting.
    Sorry. I should have included that with the pic! It's an XLR Thunderbolt 385 AMP.
    XLR 385 AMP
  • Yes that is what I currently have. As I mentioned I build a fold down desk that is flush to the wall just looking to find one that has a slide in the office area for more room.
  • The only KZ 37K I found was a sportster which shows a full size ramp door. Not sure of the model you say you have.
  • Carringb - what make an model is this so I can lookup more information? It looks very interesting.
    Y-Guy - the back ramp for most toy haulers have a ramp that is the full width of the rv approximately 7' x 7' which is what I would like as we use this as a deck. For the garage area I need an office but would also want this as usable area when I am not working. If you look at the floor plan for the Montana Raptor 3602RL this is pretty much what I am looking for except the ramp door is only 4' wide. I have talked to Keystone and the support rep said the larger door can be installed and the corners have the support just the door frame would need to move and order parts such as a new ramp door, door supports and hinges.
    I have talked to one RV body shop and they have elected to pass even though the manufacture mentioned is could be accomplished. Of course I do not have any type of estimate on the cost for the modification of the Raptor and I am still open to other suggestions anyone may have. Basically an with a ramp, generally seen as a toy hauler, that has a slide in what is known as the garage area. I say garage as most manufactures call it that but I would like this to be livable space that is comfortable and I can use as an office. I prefer a 5th wheel but I am open depending on the floor plan.
  • Not quite the same floor plan, but here is one with french doors going to a full-width ramp. It moves the bedroom into the garage, but the huge kitchen or the living room could both be used as office instead.
  • I'm having a tough time picturing what you want to be honest. But keep in mind resale value. Personally I'd look for another unit that fits the bill better rather then a massive and probably expensive add on.
  • I have already anticipated the re-framing of the wall. If I go this route and if anyone know of an RV body shop or fabricator please let me know.
  • Hopefully someone with model specific information can help.
    I know that in general there is a steel frame around that door, on many it's the only vertical piece of steel on the while trailer (I saw one burn once, all that was left sticking up was that frame).
    So modification might involve rebuilding the entire wall to expand that metal opening.
    Good luck with the hunt!
