PeteHalsted
Oct 13, 2017Explorer
I got the rebuild kit and did the job yesterday.
Taking the leg off was pretty easy and is necessary to put the new parts in. Mine is mounted with 2 brackets that are basically U's with bolts through them. I removed the 2 bolts and the leg was able to come out. As mentioned earlier, the pin going from the transmission into the leg was completely sheared so it wasn't an issue when removing the leg.
I also removed the transmission and motor. That was 2 wires. And a small bolt and nut, that goes through the crossbar that drives the other leg.
The original pin that runs through the transmission and into the leg was twisted and sheared. It took a bit to get the old one driven out of the transmission because of the twisting.
As for putting the new parts in the leg that was pretty straight forward. I found downloadable instructions and an image of the parts here https://www.strombergcarlson.com/download/Venture_landing_gear_rebuild_instructions_07022015756am
As predicted the reason mine was sheared was the leg had been ran in to far. I tried using a screw driver to pry the old gears enough to get the leg moving but didn't have any luck.
With the parts removed, you basically have the top of the jack screw that runs though the leg sticking up. A Pin goes through this and is what the gear sets and and drives the jack screw. I made a "tool" with a deepwell socket and my angle grinder that would slip over the jack screw and had groves that the pin could set in. With my "tool" and a rachet I was able to get the jack moving again. Once it had turned a couple of times and gotten back on its normal threads it moved fine.
putting the parts back in the leg was straight forward. The hardest part of the job came with getting the leg back in the RV. Remember when taking it out the pin going through it was sheared. Putting it back I had an pin sticking out of it an extra 4 or 5 inches and that was enough to make it hard to maneuver the leg in. I had to take the foot off of it and the pull pin mechanism for the dropleg and feed it in from the top. With the leg retracted as far as it would go.
Once you get the leg back in. Make sure you EXTEND THE LEG THE SAME DISTANCE AS THE OTHER LEG before you reattach the transmission and crossbar. Otherwise you have to take the transmission back off and get the legs to match. Don't ask how I know that ;-)
I plan to get a bit of reflective tape, and put on the legs to indicate how far that can be retracted. I also plan to not left my wife help setup the trailer in the future ;-)
Any questions that I didn't cover please let me know
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
Related Content
- Feb 01, 2026Community Alumni
