- pcm1959Explorer IIGlad to hear that you found a replacement. Please share the specifics of the motor and where you got it for the benefit of others with LS or similar fivers. Thanks!
- dpglifestyleExplorerFound an exact replacement online after numerous hours of searching. In researching this I found that Klauber manufactures these for a lot of companies and then it becomes exclusive to them. A lot of these have very similar specs and may be the same for all I know. I was worried about the full wall slide giving me problems but it works perfectly. Hoping this new unit solves the problem.
- bswanExplorerHave you tried going to the Carriage Lifestyle web forum? It is a valuable resource for Carriage and Lifestyle owners. Just an option.
- Fulltimer50Explorer
- sayoungExplorerTalk to the folks at E-trailer. They probably have a replacement
- dpglifestyleExplorerThanks Scottg
No it does not look like first one linked but will follow up on second link. - F-TROUPExplorer
dpglifestyle wrote:
Not sure they will even sell to a dealer. They are a manufacturer supplier.
Go to their website and see if you can search for a dealer. - ScottGNomadDoes it look the same as the K01389C525?
The difference may only be gearing and if so, this one might work but move at a different speed.
More research would be needed. You could also contact the vendor in that eBay listing for the unit you need.
Also found this listing: Link - Artum_SnowbirdExplorer
- BobKrogstieExplorerTry here - RV Salvage Sources
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
