pcm1959
May 08, 2020Explorer II
Replacing HP Metal Vavle Stems
l'll be getting new tires soon. The originals were installed when the RV was new late 2013 so I suspect the hp metal valve stems should be replaced, too. I run 17.5 tires that have a max of 125psi and I know its important to have the proper stems.
Discount Tire is mentioned here often so I wanted to ask those of you with experience with Discount if they will have these high pressure bolt-in stems? Also, mine came with longer ones and I'd like to get some that are shorter. Thanks
