ksbowman
Aug 18, 2017Explorer II
I replaced my horizontal slide out seal this summer. I got it from Pelland Enterprises on line. There are many different styles of seals so you need to know exactly what the profile of your seal looks like and the length of it. Changing mine was simple. The old one pulled right off since the spring loaded clip had deteriorated. The new one just pushed on with a click. I had one of the side seals slip down about 2" and getting it back up in the correct position was a little harder, but not bad. None of those seals were glued only a friction fit. This was on a Keystone Outback 5th wheel. The track is a mild "T" shape to let the seal snap on.
About Fifth Wheel Group
