justme
May 23, 2020Explorer
Fnp5150 wrote:
This may be a dumb question, but here goes. I need to fully retract all my jacks on my Cougar so I can zero out the autolevel feature. In the past I've hooked up to the truck and then retracted. Just saw a video where someone retracted them while unhooked (was a different brand fiver), and it worked fine. I'm worried that my camper will go so low to the ground that it will damage my drain pipes for grey and black water. Is this possible, or do the manufacturers plan for this ahead of time and build them with enough room?
I don't know what you mean by "zero out the auto-level". If you mean calibrating for level then you simply follow the instructions in the manual which don't require full retraction.
About Fifth Wheel Group
