woodtruckerExplorerSep 27, 2018RV black tank outlet plumbingAfter 4 years of ownership and many happy miles pulling the 5, I've spring a leak in the worst place. sewer... I think it happened over winter when I forgot to drain black tank completely and it crac...Show More
Edd505ExplorerSep 27, 2018Yes it's ABS, you can use ABS or PVC same nominal dimension. PVC to ABS the glues sea foam green.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problemBlack tank dump plumbing replacement?
