Artum_Snowbird
Sep 27, 2018Explorer
If you can get it dry first, and it might help to lift one side or one end to do it, then apply epoxy and wrap all the way around the pipe over the epoxy to hold it there. The trick is to apply sealant, then securely wrap all the way around and well past the crack on a dry and sanded surface.
About Fifth Wheel Group
