Just bought a 2012 Montana It Has a scare light swt on the panel The scare light / flood light will not turn off and the inside swt stays illuminated No matter if the swt is in the on or off positi...
Sounds like a bad switch. Pull it out and you should see three wires. Hot in, ground and hot out. You can at least kill it there until you get a new switch.
