- B_O__PlentyExplorer II
Dave H M wrote:
X2 a waste of time. My last RV sat outside for 10 years and was fine when I sold it.
Is your roof deteriorated?
I have never done anything with my roofs, not ever clean tem.
B.O. - TimayExplorerEternabond tape and Dicor lap sealant to correct tears and areas that have shrunk away from the original sealant.
Tim - Dave_H_MExplorer IIIs your roof deteriorated?
I have never done anything with my roofs, not ever clean tem. - yankeecamperExplorerHow bout liquid rubber
- AllworthExplorer IILanco does make product lines specified for use on EPDM. Check the tech specs.
- Jerry_BExplorerI would recommend "Duck Coat" or "Liquid Rubber Roof". Used both and satisfied with results.
- handye9Explorer IIReasons, it's probably not a good idea.
1. Urethanizers are water resistant, not water proof. If you have a flat roof, or areas where water may stand for up to fifty hours, the urethanizer will break down, allow water to get under it, and peel off.
2. If the urethanizer is made by Lanco, their safety data sheet says "Do Not Use On Rubber Roof".
3. Any sealer made from petroleum distillates, is incompatible with rubber roofing. IE: May cause damage to the roofing material.
Here's a link to Lanco info.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
