- LantleyNomadI keep my rig plugged in 24/7 365. The only time my rig is not plugged in is when it is traveling down the road to a CG or returning home
- Old-BiscuitExplorer IIIAs a FTnr our 5vr is plugged into an AC power source majority of time and over the past 6 1/2 yrs. have never had a problem with batteries. Have a converter with 3 stage charger and check battery levels routinely. At first I checked them monthly that now has moed to 4X a yr. Only have to slightly top of batteries every 3 months....IF needed.
Fridge is also always ON and so is oven pilot light. - StraboExplorerI leave ours plugged in, have for years. We have sealed AGM Deka batteries.
- BB_TXNomadI am in the "depends on the converter/charger" group. Many have reported boiling the batteries dry. Many say no problem.
I keep mine plugged in year round whether in storage or in use. No problem. First battery lasted nearly 6 years. Do add some water about once a year. - naturistNomadYou will get all kinds of "expert" opinions asking that question here. Some of those opinions might even be useful.
I will not venture to make a recommendation to you, but I will tell you about my experience. I have a 2007 TT that has one of the older style 2-stage converter/chargers. I made the mistake of leaving it plugged in at home over the winter after I bought it in Dec 2007, and in spite of checking the water level from time to time (it was never low, btw), our first trip out I discovered that the battery would not deliver power even though the voltage showed it was fully charged. When you switched on any load, even as small as a house light, the light flashed on and immediately went out, no juice. I had to buy a new battery.
Since then, when I store the TT, I disconnect the battery via a cut-off switch I installed, and I put the battery on a BatteryMinder. It trickle charges at 1 amp, and desulphates the battery, so it is always fully charged and ready to go whenever I want to use the rig. - CabinetmakerIIExplorer
freewayrandy wrote:
I keep my hauler plugged in all the time at home. My neighbor just told me a tech at a RV dealer told him not to, but plug it in once a month for a week to charge the batts. Anyone know of any cons to leaving it plugged in all the time?
We have experienced boiling the batteries in our 2001 Holiday Rambler TT by leaving it plugged in over the winter requiring us to replace both batteries. Our new (2012) Cyclone 3800 Toy Hauler has the so called "Smart Converter" Not wanting to take any unnecessary chances, we unplug from shore power when the coach is not in use and disconnect the batteries utilizing the factory installed disconnect switch. We spent 4 months in it last winter in Arizona with no issues. I do check the batteries monthly as part of the routine when I exercise the on board generator. Better to check often then to replace expensive batteries.
CURTF! (C U Round The Camp Fire) - mec500ExplorerI put my charger on a switch that I turn on when needed.that way I can keep the fridge cold and stocked
- Jayco-noslideExplorerThe manual for my Itasca motorhome recommends to not leave it plugged in except enough to keep the batteries charged. But then, if one stays somewhere long term, then it's plugged in all the time isn't it?
- donn0128Explorer IIWhats the difference of plugging in at home all the time or plugging in at the RV park for days/weeks/months at a time? Answer... NOTHING! Now that is not to say you should ignore your batteries, but there is no difference. I have had my RV's at home and plugged in since around 1977 with no serious problems, ever. All this hype about three stage converter/chargers I think is just that, hype. Check and maintain your batteries, leave your RV plugged on and ready to go at a moments notice. The alternative is not so nice if you decide to pull out on a moments notice and discover deqd batteries because you forgot to plug it in last week for a couple of days.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
