spro2395
Jun 19, 2016Explorer
Shower skylight
Hi all, Does anyone know of what we could use to block the heat from the skylight in our bathroom ? We have those foam plugs in all 3 of our vents but don't know what to use on the skylight.
MFL wrote:ChooChooMan74 wrote:
You can try reflectix insulation. I use them in the soft sided windows of my HTT.
Yes, this is what I'd use. I'd take the inside of skylight down, then place the reflectix between, put the bottom section of skylight back up. You wouldn't even see it. You may miss the light, but sure would help, if parked in an area without shade.
Jerry
