pcaffreyExplorerApr 15, 2018Slide SupportsThe question is does anyone put stands or any supports under the slide out when parked for extended period of time or is this a NoNo. And if you do what do you use. Thanks
Old-BiscuitExplorer IIIApr 15, 2018Slideouts are 'self supporting'If needed the RV MFG would have provided them to limit warranties issuesYET they do NOT Just because something is sold via aftermarket does NOT mean it is necessary, worthwhile or even an improvement.Seeing someone use something is NOT a recommendation.Check with YOUR RV MFG about the use of slideout supports for YOUR RV.
