- LynnmorExplorer IIBe sure to turn the tank valves completely open till they are tight to prevent leaking around the valve shaft.
- opnspacesNavigator IIIMake sure you get some soapy water on the breather port at the bottom of the regulator. I'll bet the diaphragm is failing. No it is not normal, you should never smell Propane unless you disconnect a line..
- Old-BiscuitExplorer IIIYou should spray all connections/fittings with soapy solution and look for signs of leaking (bubbles) WITH the cylinder valves OPEN
Spray the valve
Spray the Large Green ACME Nut
Spray the area behind the Nut where hose connects
Spray the LP regulator....crimped body, hose fittings, vent holes (small pin hole pin 1st stage and 1/2" screened vent on 2nd stage)
We would get a slight whiff after having cylinders filled....propane residue from bleeder valve.
Otherwise......NO
About Fifth Wheel Group
