fcooper
Jul 03, 2014Explorer II
Hey Johnny T
First of all, thanks for your moderating service. I appreciate what you do.
Either I am not reading your suggestion correctly or it is not stated correctly. If the coach is going to be protected from the generator as well as the campground hook up, doesn't he need to put the EMS-HW50C downstream or after the transfer switch? This is the way I've installed the one on our coach.
Fred
Fred
JohnnyT wrote:
...text removed....
If you are going to have it installed I would recommend that it be installed prior to the transfer switch... That way you are protected from the generator as well as the campground hook ups...
....text removed....
JohnnyT
About Fifth Wheel Group
