klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
4x4ord wrote:
Here is some real numbers for a 2017 F350 SRW.
GRAWR...... 7230 lbs.
Unladen rear axle... 3470 lbs
Unladen front axle... 4850 lbs
GVWR.... 11500
According to these weights and based on a 20% pin weight my truck can tow:
Based of GVWR:
Pin weight can be 3180 lbs
So Gross trailer could be
15900 lbs based on a 20% pin.
Based off GRAWR:
Pin weight could be... 3760
Gross trailer weight could be
18800 lbs.
Me Again wrote:MFL wrote:
FWIW, his 2011 had the 3.42, and like Gary mentioned, not much sense trading a late model 2500, for a SRW 3500. Now if making the choice, for towing a FW, between purchasing 2500 or 3500, most of us would choose the 3500. IMO, best to get a DRW if GVW of FW is 15K or more.
Jerry
RAM and I think FORD rates the 3500/350 SRW higher than 15K, I tow a 16K 5th will just fine with mine. If I was to tow the max 17,050 trailer, then I would have to remove a lot of stuff I carried in bed boxes to stay below 7K RGAWR.
laknox wrote:klr650goldwing wrote:
Thanks everyone. There is a wealth of information here. I checked the weight tag on my truck and found the following information: GVWR 9900, FRONT GAWR 5200, REAR GAWR 6830. I don't know how to calculate total towing capacity from those numbers. I bought this truck new. When new it had 3.73 differential gearing. I had those gears changed to 4.56. That increased the towing capacity of the truck, but I don't remember how the truck shop calculated those numbers. Can anyone determine the maximum weight 5er this truck can tow?
It's not what you can TOW, it's what you can CARRY, i.e. PAYLOAD, that's the critical number. Sure, you can tow more, but you can't CARRY any more than you could when that truck rolled off the line. First thing you need to do is to load up your truck as if you were going camping. You, passenger(s), hitch, full fuel and "stuff", then hit the scales to see what your truck weighs. Subtract that from the 9900 lb GVW from your placard. THAT is the PAYLOAD capacity that you have left to CARRY the pin of a FW (or GN). If you =really= want good #'s, then take the FW with you to the scales and weigh =all= axles, steer, driver and trailer, both with and without the FW hitched up. Do it ready to camp to get =real= #'s.
Lyle
Jerry
Cummins12V98 wrote:valhalla360 wrote:
Yes, the general rule is to pull the ratings for the truck. If you are within the rating...it's good.
NOT really, I can tow 30k or so but in a two axle 5er with 25% pin no way and stay at or under 9,750# RAWR! I look more at what the RAWR is.
Jerry
