ilvtravln
Oct 05, 2019Explorer II
ST Tires ???
Have LT tires on my fiver, thinking of going back to ST tires, does anyone have a brand they would recommend. Not to keen on Chinese tires. Size is ST 235 85 16.
Thanks
Thanks
fj12ryder wrote:ilvtravln wrote:I can only rely on what I've seen when comparing ST tires to tires I replaced them with, which at that time were LT tires. The ST tires I took off, Carlisle ST 235/85-16, had such flimsy sidewalls that, with it dismounted from the wheel, you could basically collapse the tire by simply sitting on it.fj12ryder wrote:
Just curious why you would go back to ST tires. Have you had issues with the LT tires you've been using? Personally the only ST tire I would ever buy would be a Sailun.
I have Michelin Ribs, no problems, but the ST tires have a thicker sidewall so that is why I am considering them. Axles are 6K.
One of the boasts that you seem to hear is that ST tires have stronger sidewalls, but that hasn't been borne out by what I've seen.
And if you've had good luck with LT tires, why change? You know the old saying: "If it ain't broke, don't fix it". I would stick with a known quantity. JMO of course.
Cummins12V98 wrote:Terryallan wrote:Cummins12V98 wrote:
I don’t care what they are called the GY ENDURANCE has a stellar record.
But it is still relatively new. Only been out 2 years or so? Launched Feb 2017.. Not really enough time to have a comparable record. They may well be great tires. Only time will tell.
but for now. Maxxis seems to have the best longevity record.
Two years and eight months. Show me a non road hazard failure.
Cherry on top it’s a US Made tire.
tomman58 wrote:So what hasn't been discussed many, many times? A brand new subject is very rare. It's why forums tend to languish after a lot of years. Shoot, go to any auto forum, and you'll see the same thing, or any motorcycle forum, or race forum. Any forum that has lasted more than a couple years generally has the same questions asked and answered.
Does anyone have a clue how often tires have been discussed on this site????? It has to be over 100.
Cummins12V98 wrote:ScottG wrote:
Another vote for GY Endurance. They've been around long enough for me and their record is excellent regarding blowouts and failures.
The only thing I don't like about them is they are subject to rock mining, where a sharp rock will burrow all the way down to the cords. Most tires wont do this but mine have several places where I can see the silver cords after removing rocks.
Have you contacted GY about the rock issue? Just over two years on mine on boat trailer with no issue like that. In and out of gravel nearly every day in the Summer at boat launches.
I also tow at 70 where possible.
Me Again wrote:laknox wrote:
Why? We don't even know what FW the OP has. Unless he's got a 15k+ rig, why not stick with a good E rated LT like a Michelin Rib or Bridgestone Duravis?
Lyle
A little searching of his posts shows
"We have an 09 Bighorn 3370" That model has a 14K GVWR. I agree on Sailun's for tires. Run them at 80-85 PSI.
guidry wrote:
After having tire problems I ended moving up to G load range, Hartland tires from Discount Tires. Great tires and good price.
