rhagfo wrote:
laknox wrote:
OK, guys. Here's the straight scoop from a B&W engineer. As I contended in another thread, he said that the Turnover Ball base and Companion FW hitch =system=, carries the vast majority of the pin load through the hold-down receiver and into the TO Ball base and to the truck frame. The feet of the Companion =stabilize= the lateral forces to the bed and carry very little of the pin weight. He called them "outriggers, in effect". Doesn't matter that there's a certain amount of tension on the draw-down bolt, or not; you have to look at the entire =system= to see where the forces are acting.
Again, this was direct from a B&W engineer and not something I pulled from the same place that RV dealers pull MSRP numbers.
Lyle
:h :h :h
Must be a heck of a lot of deflection in the bed floor then!!
The "Hold Down Bolt" is tightened to 40 ft. Lb. as the the hitch is installed. so the whole assembly is now pressing down into the bed on the base, not the ball base.
Now the "U" bolts are tightened around the RV post to 80 ft. lbs.
So to put weight on the RV post you will need to deflect the bed a bit.
Not so, according to B&W. The hold-down bolt pulls the hitch and the base together, but the base still supports the majority of the weight, just as it does when you're using the GN. Yes, you do get some flex, and the bed =does= support a small amount of weight, but not much. As I said, the footprint of the Companion stabilizes the lateral loads acting on the hitch system. Because the GN is hitched so much lower, you don't get these stresses because they are 1) less and 2) transferred directly to the truck frame. With the hitch point being higher for the FW, you now have that leverage acting on the base to flex it slightly, so you need to have the support for these tortional loads. If there are no lateral loads, the base still supports nearly 100% of the pin weight. Think about why most of us won't use a GN adapter on a FW. You're taking those loads and moving them to the FW =frame= instead of the truck bed. Those forces don't simply disappear; =something= has to absorb them.
According to B&W, there are several reasons for the bed deflection issues, especially with GM. #1 reason being the thinner metal used in the bed means they're just easier to crush. Second, the Companion base is a one-size-fits-all and the Big 3 truck frames are not spaced the same. GM uses the widest frame, so the support point on the frame is =not= directly beneath the center of the contact point of the Companion, but actually towards the outside. Ford is slightly narrower and Dodge is the narrowest frame. They found that these were the 2 main contributing factors to the bed deformation issue.
I'm really not making this up; I =called= B&W and asked them. I had a 20 minute conversation with one of their engineers and got the scoop from him.
Lyle
