Reelay wrote:
Dayle1 wrote:
No sealer, but it won't take much water to cause swelling on any laminate flooring.  Better option in an RV is Allure vinyl planks from HD.  But my personal preference is no-glue sheet vinyl, like Tarkett Fiberflor,  doesn't curl or distort like cheap, thin vinyl.  EZ and clean trim out.  Installed it in my last trailer and still looked great after 5 yrs.
We are seriously thinking about installing the Allure flooring planks. Most likely this spring when the weather warms up. Do you have to space the flooring from walls, cabinets , ect. for expansion? We watched a "You Tube" on an install in a house but he did not use any spacers for possible expansion. I would use quarter round and nail it to the wall or cabinet to dress it up and let the flooring expand. Thanks.
Ray
Floor area is much smaller in an RV compared to a house, but temp extremes are worse.  Also, RVs flex, so you should leave a 1/8" gap at all vertical surfaces.  Quarter round is rather large moulding for use in an RV.  Shoe moulding or screen moulding is plenty wide to cover a 1/8" gap.
