MrVan's avatar
MrVan
Suburban Water Heater AC switch at the water heater
I've got an intermittent AC outside switch on the Suburban Water heater and the original had the little spring clip to help avoid inadvertently turning on the water heater switch accidentally. In my search I have found that the original switch was part # 232362 which seems to have been replaced by part number 232259. It appears that the new switch doesn't have the hole in the rocker for the spring clip. Anyone happen to know what the new switch provides that the old one didn't?
  • My guess is that the "new" switch w/o the hole is just a cheaper of the shelf part.
    FWIW, there's nothing special about the switch. You can go to any HW store and get one that will work fine. It's a simple SPST switch.
