Gearitis wrote:
I went to Home Depot and bought a 100 ft long by 6 ft wide roll of sun shade fabric and then cut it and then put grommets in it.  We use it on the awning or around the shelter at the campsite.  I have hung it between trees to cut down the sun from the west.  I have draped it off the side of 5er to knock some of the sun off.  I can high recommend it.  I think it cost about 85 bucks for the roll.  But we have used it a lot over the past 2 years.
10X
It sure does have many uses and easy to put up and down anywhere.
I also have another piece of sun shade that I use as a patio mat instead of those heavy costly RV mats that barely last one season.
Put grommets on sun shade material on all four corners and stake down.
Mine is as long as my MH, runs from front to back.
Water goes right thru. And more importantly it is NOT slick like those darn RV mats that send you slipping and flying when wet, and also weigh a ton wet when you try and store that behemoth roll in your bays because it never dries out.
With the sun shade material,
If wet all you have to do is hang it up or throw it over the picnic table before you get ready to leave and it dries in nanno seconds. Weighs practically nothing AND 'folds up flat' into a square for storage in the bay.
