outlaw85
May 11, 2016Explorer
midnightsadie wrote:
theres always going to be some thing that needs done,just part of owning a rv, fix those wires or they could short out and cause a fire . mice, use peppermint oil put drops in and around your rv, fill any hole you find .its all part of the fun.
We haven't even gotten to have fun yet. :)
The wires are definitely on the to-do list. Short term- I am going to wrap them to protect them from stuff hitting them. If I can get in there I would like to heatshrink it. Not that it matters (wires are wires) but I think they go to the tank level sensors. Before attempting to fill, the gray tank was 0, after it sprayed out of the fill neck, it was 1/3. I opened the tanks and nothing came out. Checked yesterday after everything looked to have dried and the gray tank is back to 0.
Thanks for the tip of peppermint oil. The PO had mothballs everywhere. Still smells minty! lol
Thanks for the help. I'll keep my updates here for the enjoyment of 'The Camper Saga'.
Outlaw
dahkota wrote:
Spray foam is great for filling mouse holes.
Is the leak current or old? Where is the furnace located? We have had water around/under our furnace twice: fridge drain line (on right of furnace) and a hot water fitting was dripping under our sink (on left of furnace). Neither were in the sub-floor or the furnace, that is just where the water ended up.
The fill neck can be patched if it is gravity fed. Our gravity fill is near our furnace and water sloshing around while driving might potentially end up under the furnace.
I think you should keep going. By the time you finish you will know the rig inside and out. You will also know the quality of work done and can be confident in the repairs. We bought ours new and, like anything else, need to maintain and fix it occasionally.
I will have to invest in some spray foam for when everything is done. The furnace is just below the fridge. The fill lines are on the opposite side from the furnace.
We just took ownership of it in Nov-Dec and have just now been able to go through it with the weather finally getting warmer. I believe it to be from the mice because of what I've seen already. When I connected the city water line, I could hear the water spraying out under the floor. I was hoping it was just above the bottom cover but no go.
The fill neck is gravity fed but the hole is about the size of a golf ball. I jokingly told the wife I would just double up on duck tape to fix it. :) She wasn't really happy about that or all of this really.
I can't say I am either but it's either fix this as we go or take a monthly payment on something else. If this only costs a couple hundred to fix what I've found so far. I can live with that.
Thanks for the motivation. I do agree with all of this forced learning. It isn't an ideal scenario since our first weekend with it is coming up in a couple weeks. Worst case is we wont have any water so not too bad.
Current plan- Remove furnace and cut a hole in the floor to look for leaking pipe.
I will be sure to post up some pictures since everyone likes those. I'll use this thread as a log for anyone interested.
Thanks again, and please keep the info coming. I can't get enough.
Outlaw
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
