Jim4929
Aug 17, 2013Explorer
Third Dometic 9100 Awning Failure
Today I returned home from having a THIRD motor put in my Dometic 9100 series awning. I extended it to dry out the awning and tried to retract it and the same problem occured....tink tink when the buttor is pushed. The first two times it failed, at least it was retracted, but now it is extended. This trip both the switch and the motor were replaced since Dometic said the swith might stick. Am I just the unlucky one or is there anyone who has similar experience? If so what was the final fix? What other things can cause the motor to fail. It's still under waranty, but is just a PIA to keep going back and getting it fixed. I also know that if I had a manual awning this would not have happened, so that doesn't need to be pointed out.
