Cummins12V98 wrote:
time2roll wrote:
Not just balanced but I make them use the lug centric hold down.
Please explain what that is???
Most use hub centric where a cone goes in the center hole to center the wheel on the balancer. Most aluminum wheels are pretty good but many steel wheels just have a punched hole that is not perfectly centered.
Lug centric uses an adapter that centers the wheel using the lug holes that have a taper to them and center the wheel same as it is mounted on the vehicle. This method will not have any chance of off-center based on that center hole.
Many cars and trucks have oem wheels that use a machined center hole that fits snug on the hub and these are fine for the hub centric cone. So the shops get used to this faster method and do the same for trailers.
google may have additional info or pictures.
