psford
Oct 29, 2014Explorer
Tire Wear
Friend has a Montana fifth wheel with some unusual tire wear . The outside edge on one tire on each axle has worn almost down to the cord. The two worn tires are on opposite sides from one another. The other two tires on opposite sides from each other look nearly new. You would think the wear would be on the same axle or on the same side with an alignment problem. Anyone have any ideas what could be causing this. The tires are the Goodyear Marathons
