Hermes1
Jun 15, 2017Explorer
I agree you should first thoroughly clean the mouth of the toilet, paying particular attention to the rubber gasket. Then as long as you are at it, just lube the gasket, but do not use Vaseline or any other petroleum based product, instead use plumbers lube which is not expensive, readily available and the right product for the job. If it still leaks, then the gasket needs replacing.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
