MNRon
Jun 16, 2017Explorer
If it's not the obvious like something stuck in the seal, I would then suspect the seal compression. Does the pre-fill work fine (hold lever down to fill bowl)? If not it could well be that the rubber seal is not compressed sufficiently. We had this a year ago. Simple fix by righting the four bolts that hold the top of the toilet down and compress this seal.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
