Edd505
May 22, 2019Explorer
happycamper1942 wrote:
I had that problem a couple of years ago. It was the dreaded "pyramid" which had built up directly below the toilet entry into the tank. It took a lot of hours to clear it using rods, snakes, pressure washer and chemicals.
Good luck with it.
If this is the issue try dumping and then put in 10-15 gallons clean water & drive. Repeat. See if the water sloshing will break it up.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
