MFL
Jul 05, 2015Nomad II
You didn't mention what size axles you have, but I am guessing 5,200, or 6,000.
I have 5,200 six bolt axles on my FW, and I torque the nuts to 95#s.
You may have caused some stretch to the studs, but if you did not strip anything, you may be alright. I would back them off, set the torque to 95, if 5,200# axles.
At this point, you need to recheck torque often, as you should after any removal of the wheel. If the nuts stay tight, after several times tightening, you should be okay.
I would continue to check torque on a regular basis, as you should anyway.
Jerry
Jerry
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
