Michelle_S
Jul 05, 2015Explorer III
If you have 5/8" studs, which you probably don't, 150 probably would be OK. If on the other hand you have the typical 1/2" studs 100 to 120 should be more than enough.
I have 9/16" studs and they are torqued to 120 to 130 per the wheel MFR spec.
If you have Steel Wheels it may be different, I'm only familar with Alumium wheel specs.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
