2006 Dodge Ram Mega Cab Dually
gross vehicle weight rating (GVWR) 10,500 lb
payload capacity up to 3240 lb (depending on trim)
rear gross axle weight rating (GAWR) 9,350 lb
maximum trailer weight of 15,600 lb (course trucks gvwr and actual payload will be reached long before max tow rating is reached)
5.9L CTD
The 2005 to 2007 Cummins was rated at 325 hp @ 2,900 rpm & 610 lb-ft @ 1,600 rpm.
6.7L CTD
2013 - 2014
• 350 hp @ 2,800 rpm-------• 660 lb-ft @ 1,500 rpm (manual trans)
• 370 hp @ 2,800 rpm-------• 800 lb-ft @ 1,700 rpm (68RFE trans)
• 385 hp @ 2,800 rpm-------• 850 lb-ft @ 1,700 rpm (Aisin AS69RC trans)
Either Cummins motor is capable of pull a heavy load..that's what diesel do
Towing is not just about pulling, it's also about the vehicle's capability of carrying the load and controlling it.
Your 2006 can't carry the load and neither does that 2013 2500
Oh never mind.......facts are not what you or others want to read :S
