Go weigh your truck 'camp ready' (you, passengers and any stuff that would be in the cab)
That weigh ticket ($10-$12) will be priceless in figuring out what you can really tow within your trucks ratings.
Weigh ticket will have:
Front axle weight
Rear axle weight and
Total trucks weight.
Compare those numbers to your trucks ratings
Truck GVWR 10,500 minus actual total weight
Truck FAWR 4,750 minus actual front axle weight
Truck RAWR 9,350 minus actual rear axle weight
With that 9350 RAWR you will have more available axle weight but will reach GVWR of truck quickly.
Truck will probably weigh in around 7500# (or more)
10,500 - 7500 leaves 3000# before reaching GVWR
That CY4100 lists a 'dry pin weight' of 3000#
So before you put anything in that CY4100 you have max'd out your trucks GVWR.
Your truck has a max tow rating of 15,550# (mfg. published number using 150# driver and base model).
That CY4100 has a 'dry weight' of 14,595#. That is only 955# less than your mfg. magical max tow rating
Look at the data plate on your trucks door.
Weigh the truck....do you own figuring.
You have plenty of rear axle..just not enough overall truck.
Mega Cabs have lower ratings due to that MEGA CAB
Can't compare 2006 against a 2015. Completely different engineering/frames/suspension/engines/transmissions etc.
Apples and oranges
Yes there are lots of big/heavy trailers being towed by 2500 and 3500
Most, if they would be honest and get weighed will be overweight
The RV Safety & Education Foundation data indicates that 57% of all RVs on the road exceed one or more weight safety ratings.
Additionally, the following exceed at least one rating:
60% of all tow vehicles
51% of all travel trailers
55% of all 5th wheel trailers
50% of all trailers exceed the GVWR
After you get your real numbers (weighed) here is a 'tow calculator' to help figure what you can tow within ratings.
If rantings don't matter....ignore
RV Tow Check
