Me Again wrote:
DazedNConfused wrote:
Does that mean the truck can't handle it? No. You will likely be under your rear axle rating if you stick to a trailer with a gross of 12,000lbs or under. But will you be over GVWR? Yup...sure will if you approach that much trailer. Will the truck care? Probably not. Will the DOT care if you were sent to the scales? Yup...and they'll be happy to drain your wallet of all remaining cash.
- DNC
Could you detail what a state weight enforcement officer would be ticketing one
for.
* Being over federal bridge weights - not likely
* Being over 600(or whatever your state allows) pounds per inch of tread width - not likely, as this is higher than most LT tire ratings.
* Being over the Max weight at xx inflation mark on sidewalls - some states have that in their codes
* Being over the paid tonnage in some states - your mistake
* Having an unsafe looking load - again your mistake
So what is it you think they are going to use to drain ones wallet, as they do not drain hotshot drives wallets that tow a lot more than 99.999 percent of RVers.
Chris
I have never had this happen to me...so this is only what surfaces when I research -- but the top two I've seen are:
1) Your truck displaying more weight at the combined axles than the truck's declared GVWR by the manufacturer -- in my case, 10,000 lbs
2) Having a GCVWR more than you have declared on your weighted tag.
I have seen the fines for the 2nd one be very steep. There is debate over what you are declaring here -- just the trailer or the combined weight of trailer and tv. For NC, I have seen lots of "opinions", but I made three different calls to NCMDV, spoke with 3 different people (thought that was a reasonable sample), and got the same answer from all 3 -- it's the combined weight. I planned on getting a tag for 12,000 lbs to cover my camper. I ended up getting one for 21,000 to cover both -- but the price per 1,000 lbs of declared weight goes up exponentially as the total weight goes up. Fun.
