85raymond's avatar
85raymond
Toy hauler under belly construction
I am looking at a xlr 380amp, cyclone 3800 I would like to know if anyone has seen how the underbelly is constructed . Cyclone says they have insulation and ducted heat in there underbelly with the arctic pack u get 120v heated blankets. Xlr says 12v blankets for the tanks but they make no mention about insulation. Xlr talks about there r factor for the walls ceiling and floor but not the underbelly. Cyclone talks about the r factor for just the walls. I need the best insulation and dual pane windows I travel for work and I end up in some cold and hot places. I know there are a couple fancy toy hauler companies out there but I can't afford 120+ I also like the voltage but the 385 felt to tight
  • So basically I should not worry about the under belly construction since I'll have to do it my self. What u described sound's easy thanks for sharing
  • IOWASTROKER wrote:
    Our 2012 3950 Cyclone has no factory belly "cardboard". There was no insulation, unless you consider the black plasic below the plywood as insulation. 3 3-inch holes cut on bottom side of main heat trunk...but the way the belly "hangs down"...guarantee it will not keep the tanks from freezing.
    I threw the belly cardboard away. 1.5inch styrofoam on inside edge of the Ibeams, then 1.5 inch styrofoam with ProPanel II steel panels screwed to bottom of I beams. Dropped a remote thermostat sensor into basement: usually 8-10 degrees warmer than the living quarters:))))))
    I'd love to see pictures of this too.
  • Iwoastroker I have been thinking of doing something like that. I would like to see pics of that, got any you can share?
  • Our 2012 3950 Cyclone has no factory belly "cardboard". There was no insulation, unless you consider the black plasic below the plywood as insulation. 3 3-inch holes cut on bottom side of main heat trunk...but the way the belly "hangs down"...guarantee it will not keep the tanks from freezing.
