SeaVee's avatar
SeaVee
TPMS with Truck or Aftermarket
I noticed on some of the new tucks today, you can get them with Trailer TPMS monitoring. It seems they monitor pressure, but not temperature. I know most aftermarket systems like TST monitor both.
Having a system with a built in screen would be nice with one less screen to look at, but wondering how important is temperature monitoring? They systems cost about the same, but more just wondering the best way to go.
  • My truck came with the optional 4 TMP sensors ($50) option. When I get my 5th wheel I have to have the sensors installed. They will read temp and pressure and display it on my dash. It is part of the towing option om my 2020 GMC.
  • Lynnmor wrote:
    way2roll wrote:
    Lynnmor wrote:
    The temperature feature only reports the reading beyond the valve stem, that is not going to be a reliable way of determining brake and bearing issues.
    You may have to explain this to me. If I have a brake stuck and it heats the wheel which heats the tire and I see it on my TPMS, how is that not helping? By deduction, if my PSI is where it needs to be I can assume there is another problem than the tire. Are you suggesting a high temp reading on a TPMS isn't helpful? I sure would want to know if one wheel was significantly hotter than another. Sure beats not knowing.
    I do have the TST 507, the sending unit is whipping around in the wind keeping the temperature down. It would take extreme heat to bring the sensor to the point of alarm, but by then the air pressure would have climbed to the point of alarm anyway. I had Chinese wheel bearings that were failing to the point of turning all the red grease metallic gray and the TPMS showed normal temperatures. Helpful? Maybe a little.
    Interesting. I too have the TST 507 and find it pretty accurate. Friend shot his high dollar laser temp gauge on my tires and they were pretty close to what the TST read. It even picks up small changes like when one tire was in the sun while driving as opposed to the other side that was not. Maybe yours needs calibrated. To each his own, but I prefer to have both PSI and Temp and find each helpful and fairly accurate.
  • The temperature feature only reports the reading beyond the valve stem, that is not going to be a reliable way of determining brake and bearing issues.
  • Temperature monitoring is important. An underinflated tire will generate more heat and alert you to the problem before a blowout as should PSI monitoring however, temps can also be indicative of a hung brake, and overheating hub etc. If you are going to get a monitoring system, you might as well get one that monitors everything.
