Merlins's avatar
Merlins
Trailer hitch for fifth wheel
We've received conflicting information as sto whether or not we should have a slider hitch for our Brookstone fifth wheel. Please give us your thoughts.
We have an F350 crew cab short bed (6 3/4 ft bed)and a Coachman Brookstone 325 RL fifth wheel.
  • I have a 2010 Brookstone 345SA and the same truck, I purchased Reese 20K round tube slider. I have never had to use slider. I have backed up with camper at 90 degrees, and nose of camper did not touch cab of truck.
  • Like attman6 said the pain goes away after awhile. I went with an auto but you could save some money on a manual model. Then you just have to remember to get out and release it. My rig is 8' 6" wide with a flat front.
  • Seeing that you added the info, I will give my 2 cents. It looks like this camper is made for short bed pickups with its Turn Tec front cap. But, I would make sure from other owners of coachmen products to answer. I am still looking up on their web site. (Hint: Google is your friend)
    Brookstone Top 10 Features (#1 answers your question)
    Brookstone PDF wrote:
    #1 Turn-Tec Engineering
    Why spend money on expensive slider
    hitches? Each Brookstone is built with
    a frame with chamfered (45 degree)
    corners that when combined with the
    aerodynamic front cap creates the
    industries most
    maneuverable luxury fifth wheel.
    Nothing turns like a Brookstone!
    90° TURN - NO SLIDER NEEDED
  • Based on the info you have provided.
    YES....NO.......MAYBE
    On EDIT:
    With a shortbed it really depends on how the front cap of 5th wheel is designed.
    Measure from center-line of king pin to the outside edge of 5vr.
    Then measure from 2" forward at center-line of trucks rear axle to back of cab (center and at corners).
    Will the measurement of 5vr hit truck cap.........need a slider
    Will the measurement of 5vr NOT hit cap.......might need a slider if it is close due to cocking of 5vr when truck/trailer are level ground.
  • Pretty easy decision for me, I don't want to dent my truck. I have a short bed,so question solved. It just took a painful bite out of my wallet.The pain only last's a little while.
  • What truck/bed?????????
    What Brookstone??????????
    A little information goes a LONG ways on here.
  • If your trailer is going to hit your truck on a tight turn, you might want a slider hitch.
  • Waste of money on an 8 ft bed.
    Might be a good idea on a short bed
