Oaklevel wrote:
Just asking????
Why will many tire dealers refuse to put LT tires on trailers?????? There are two large tire dealers here that would rather lose business than put LTs on trailers
Mostly it's because the LT tires will end up having slightly less capacity that the axles. Not usually a problem if you're able to go from D's to E's, though there aren't many trailers that are delivered with 16" D-rated tires. Had I a bit more room in my wheel wells, I'd've probably converted to LT's a long time ago.
Lyle
