mabynack wrote:
I checked the rating on the rims on my 14,000 lb fifth wheel last night and they're rated for 3045 lbs. I couldn't find a pressure rating on them, so I'm still not sure if I can go to a load range G tire without changing the rims.
OK I am going to explain to you how to have many miles of happy trailering.
Measure center to center of your axles!
Greater than 33 inches - Install LT235/85R16E Bridgestone Duravis R250's
Less than 33 inches - Install LT245/75R16E Bridgestone Duravis R250's.
If you want to spend a couple hundred more to for no good reason then install Michelin XPS RIBs.
Compare the tread pattern to the high end GY G614 trailer tire.
Do it and don't look back!!!!!
Your trailer depending on year may have come OEM with load range D ST tires rated to 3000 pounds, so a LT tire rated to 3042 exceeds that, and it a MUCH better tire!
Chris
