aruba5er
Apr 15, 2014Explorer
the turn filament is the same as brakes in a standard 1057 lamp so When you signal that filament flashes and if you have your foot on the brake the other stays steady. Thats the way it is supposed to work. I added side markers/turn years ago and grabbed the wiring just after it entered the basement after it came thru the kingpin. so easy. I hot glued the wiring along the sides of the basement walls.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
