nick11 wrote:
No doubt the BD3 is an awesome hitch and has some articulation. The drawbacks are that it weighs 160 lbs, is over $2k and you need to be pretty level and straight with the trailer to hook-unhook. With the Anderson you can be un level and at 90 deg to your trailer and still hook - unhook with ease. It also rides great going down the road with no airbags to deal with. Extremely simple, easy to use and easy to remove.
Sounds like salesman chatter. I have been using the TS3 for 8 years and it does a great job. It uses the same Holland-Binkley hitch head as the BD5. It is not hard to hitch, and you do not have to be straight or on level ground as you falsely believe. I have hitched and unhitched at nearly 90 degrees to the trailer.
I have had to help several people get their trailer unhitched when the ball is jammed in the receiver. You wind up putting blocks under the front jacks so that you can lift the ball and pin clear of the hitch and then beating the ball and pin until it releases.
As for the weight and price, you get what you pay for. No way would I consider pulling my trailer with the Anderson hitch.
Ken
