kp_utah's avatar
kp_utah
Trojan T105 Batteries - Need a charger
I just replaced my 12V batteries for 2 6v T105 225AmpHour deep cycle batteries run in series to make 12v.
I have a schumacher charger that does 2/6/8 Amps. It takes forever to charge! The battery vendor says I need to use a charger whose amp rating is 10-13 percent of the AmpHours of the battery and that I need to charge it to 14.8V. That means a charger at 23Amps or more. I called the battery vendor, he wouldn't give me brand names, but said even a 20amp charger would be fine.
Ok, what charger can do that? Anything reasonable? Like under $100? I see some fancier ones (Pro-logix, Iota, Genius, etc), but they are all upwards of 199-300 and more. I am not against going there, but I was hoping to find a decent portable smart charger I could use for everything. Truck, ATVs, RV, boat, etc. Or is it best to just get one I install and leave in the system.
I plan to get a hydrometer to test the specific gravity. I read that its the best way to measure the charge.
Back the topic... A recommended charger for charging 2 Trojan T105 225AH batteries?
I have a 29.5 5th wheel - 2004 Mckenzie.
Thanks a ton in advance
