zigzagrv
May 30, 2015Explorer
If you have the manual for the slide system, there should be a procedure in it for opening/closing the slides manually. If you get them closed, put a slide lock (if you don't have them, they can be made with a simple piece of wood cut to the right length) in each slide to prevent them from coming out while moving. Good Luck!
About Fifth Wheel Group
