Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
C-Bears wrote:
You should purchase the truck you need for towing the fiver you either have, or the fiver you will be getting.
It is as simple as that. It you have to have the DRW to handle the pin weight then it really doesn't matter if it is hard to park, gets .5mpg less in fuel usage, or costs $50.00 more or less to maintain each month. It is the truck you need for the job you are using it for.
On the other hand if the anticipated weight isn't even close to needing a DRW truck then don't waste your money and stay with the convenience of a SRW.
352 wrote:Correct (usually) if you are referring to TOWING capacity, incorrect if you are referring to CARRYING capacity.
Stability only. Weight capacity is less on a dually.
The Mad Norsky wrote:
Please remember that as far as maneuverability goes, it is usually NOT the dual rear wheels that makes the difference.
LENGTH of the vehicle is the real problem, and this exists for both single and dual rear wheel vehicles.
Considering most pickups sold today are crew cab versions of some sort, adding in either short or long box onto that makes for a long vehicle, irregardless, as I said, to dual or single wheels in back.
And it is usually this length that makes it tough to turn into parking places.
NC Hauler wrote:agesilaus wrote:
Go to the manufacturers website for that truck model and look at the specifications. You'll see that the DRW has a higher towing and carrying capacity than the same model SRW. You give up maneuverability which even with a SRW is all that great. You probably take a hit on fuel mileage too with a DRW. Plus your tire expenses increase by 50%.
Whether you need a DRW depends on what you expect to tow. SRW will tow medium sized fifth wheels easily, but when you get to the longest and heaviest fivers you'll want a DRW.
What expenses increase 50%?:h.
