lee worsdell wrote:
here is what I weighted in at on my last trip. Some one please tell me where iam over iam pretty sure I am. driving a 2013 gmc 2500hd duramax,single axles slt model. front axel is 4806,rear axle was 6128 with trailer hooked up fifthwheel. The trailer came in at 9259 it says the trailer can weight 13300 loaded
Look on your door post for the following information.
GVWR currently 10,954
FAWR currently 4,806
RAWR currently 6,128
If those numbers are less than your door sticker you are fine.
You will have to weight the truck by itself to get the actual trailer weight. Example: If the truck by itself weighs 8,000 subtract that from 10,954 which would give 2,954 pin weight. Add the pin to the trailer axles for the trailer weight, in this example the trailer weighs 12,213.
