Shipwreck2's avatar
Shipwreck2
Truck/trailer weight help
Hey all first post here
We had decided to move up to a fifth wheel so upgraded the truck and bought a fifth wheel and all was good or so we thought. I am supposed to pick up the trailer this Wednesday(in 3 days) and while searching on slide or no slide I found I made a big mistake. We bought a f150 ecoboost with the max tow package thinking that gave me 3000lb cargo and 11000lb tow. Found out that for the 3000lb I need the max cargo option I don't have.
We purchased a cougar xlite 28rbd with a tow weight of 7000lb and pin of 1400lb.
To make sure I don't do a repeat on the truck I'm Herero make sure I don't miss anything. I am now looking at an f250 crew cab 4x4 6.5' box. Dealer has listed it on the website as 2800lb cargo and 9300lb tow capacity even though it has listed the tow package option.
Will this truck/trailer combination make a good pairing? If not what specific features/options do I need? I need to figure out something quick or I will have to start paying storage on the new trailer so I am limited on truck options.
Thanks in advance
  • For the trailer that is the dry weight cargo weight is 2000lb.
    For the truck I am unsure as I have not yet spoken with the dealer only what is on the web.
    The other part that makes this more urgent is that we are currently in a 10 day camping trip in our current trailer. Wednesday I was to spend the day driving the current trailer to the dealer and swap trailers then continue our trip. Our trailer has already been sold by the dealer so if I can't correct the truck then trip is over
    Drcook I was under the impression legally there is nothing I can do aftermarket to increase the cargo rating of my truck? The only feature the current truck is missing is max cargo which I believe the major change there is an axel and wheel upgrade along with springs.
  • Are you going to keep the trailer at your home ? If so, you could look into what it what cost to have an RV hauler put it there for you. The dealership would know of local ones. Or ones coming in with a load and having a side paying job could help someone from having to dead head back.
    This would give you time to make a decision and lessen the potential financial loss from having to make a hasty decision.
    As far as the truck, what is the difference in the options on the truck you already have ? Is it springs (fixable, not a terrible amount of money), rear-end gears ( a more pricey, but fixable issue) or what. If you could upgrade your truck to what you need for less than what you are going to lose by trading again then you could be further ahead UNLESS you intend to upgrade the trailer again and need a bigger truck.
    You need time to look into engine combinations, rear gear ratios all the stuff that will come into play depending on where you intend to go with the unit.
    At least that is my take on it as 1 hasty decision can lead into another if you don't have the latitude to step back buy correctly this time.
  • Real world diesel 2500 series is going to scale around 8000 pounds, gas motor version maybe 7500 pounds. What is this trucks GVWR as posted on the drivers door post?
    The fivers numbers you listed, are those GVWR or dry numbers from the brochure? Again, you need the fivers GVWR from the tag on the left front corner. Pin weight will be approx 20% of loaded, or for you the fivers GVWR. As long as the numbers work out in the worst case you should be OK.
