- DuctapeExplorerI unhooked a few time at large angles. Pull the latch and lift the pin straight up off the fifth wheel with the landing gear.
Not easy to hitch up that way, usually I could reposition the truck and back straight in later. - pennysmom09ExplorerWe have the superglide and always straighten the truck before unhitching. Putting it in park, or giving it a bump in reverse, after chocking the trailer, always releases the pressure and allows the release handle to easily come out.
- cpaulsenExplorer IIOn my Superglide.....I always unhook no more then 10 degrees off center.....and that is what Pullite says to unhook or hook up.
- CampinfanExplorer IIII don't have a SuperGlide but what I do is after I chock the tires,I put my truck in neutral and take my foot off the brake. It takes the pressure off the hitch jaws and then I put it back in park, set the brake and go out and pull the handle. Releasing the tension really helps. Maybe it will help the SIL also.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
