Texas_Bob_140's avatar
Oct 31, 2013
Upgrading Tires from 15" to 16"- 2006 Cougar 285 EFS
On our annual trip from Double Oak, TX to South Padre Island, TX we blew out two tires and the wheel opening J wrap, fender and wheel well liner and damaged the wheel. The blowouts were within 5 miles of each other. The tires were ST225/R/15/D's. One was a 4 year old Goodyear Marathon with little mileage on it that blew a hole the size of a tennis ball in the sidewall. The second tire was a Mission that had never been used and was the spare and had been covered its entire life. The Mission spare shredded after 5 miles and caused the damage. Weight on the tires is around 8,000 lbs. as measured on the Cat scale at the local truck stop and all tires were aired up to 65 PSI. I also have Tireminder sending units on each tire and there was no warning of any problem.
I'm planning on upgrading to a 16" wheel with a BFG Commercial T/A LT225/R/16/E tire. The BRG's have a diameter of 29.4" per BFG and the Goodyear ST's have a diameter of 28.3" Center to center distance on the tandem axles is 33" so I will have clearance between the wheels of about 3.6". There is plenty of room between the ST's and the frame of about 3". I have checked out the slide out mechanism and the closest the slide out bar/track comes to the ST tire is somewhere between 5 1/2 to 6 inches.
The limiting factor seems to be the distance from the tire to the wheel well liner. On the present ST's, the distance is 2 1/2" With the LT tires, that should be reduced to about 2". Interestingly, there is no real liner on this trailer - it appears to be plastic coated fabric which looks like the cheap plastic coated tarps they sell at the home stores.
I will be replacing the wheels with 80 PSI wheels and metal valve stems.
Any thoughts or counsel, especially anyone who has made this modification to this year and model trailer, is appreciated. Thanks.
  • After numerous issues, I did the same mod to my 2006 11K GVW TT.
    Tire problems solved. You will not regret it.
  • Texas Bob 140 wrote:
    The bolt pattern is 5.5"-6 lug and is available on the internet from multiple sources. I buy from Southwest Wheel which is in Dallas and also on the internet. My main concern is whether the 2" clearance from the tire to the wheel well is sufficient.
    Welcome to the forum.
    I had the same issue. My used 11200 lb trailer came with new ST225/75-15 D Marathons the dealer had just installed on 5200 lb axles. My Goodyear truck tire dealer gave me a great deal on swapping to 16" LT215/85-16 E at 30.4" tall.
    I have 1 3/4" at the top of the tire and 1" on the inside. The tires tread have rubbed the sheet metal liners slightly when crossing a ditch and one wheel goes all the way down forcing the other up into the wheel well but never touch on the road at speed in any situation. No issues from the light rub.
    Sound like a good plan for 6-8 years and 40k-60k miles of trouble free tire issues.
  • I did this in 2009 with my old 5th wheel, a 2001 McKenzie Lakota. Like you the only clearance issue I had was from the top of the tire to the bottom of the wheel well, my axles were already flipped so I had 2 inch solid steel blocks added to rise the trailer and that gave me the clearance I needed. I had at least 6 blowouts with the ST tires, after changing to the BFG Commercial T/A's I had none.
  • I got the 5.5x6 wheels from etrailer $195 and 16" LTEs for $605. Craig
  • As for wheels, if you need to replace, you might consider aluminum Sendel wheels.
    Good choice to go to LT tires and get away from ST, in my opinion and experience. Hopefully you have the room for suspension travel to go to the larger diameter tires.
  • Are there extra holes in the spring hangers that would allow you to raise the trailer? Chris
  • The bolt pattern is 5.5"-6 lug and is available on the internet from multiple sources. I buy from Southwest Wheel which is in Dallas and also on the internet. My main concern is whether the 2" clearance from the tire to the wheel well is sufficient.
  • Not the same trailer but I did exactly the same thing and loving it. :)
  • what's your bolt pattern and diameter. I tried to do this earlier this year, but could not find rims. I am on a 5.5" 6-bolt rim...
    ended up on 15" e-rated tires again, which worked well last time..
    bryan
