NC_Hauler
Dec 03, 2014Explorer
jtguyton wrote:
I am thinking about upgrading to a 2008 Kountry Aire 5th wheel that weighs-in @ 19,100 (empty weight). My 2011 Ram crew cab Dually (3.73 gear) can manage 21,000 lbs. Not a full timer so the most cargo I would carry is <200 pounds.
I know most folks that own these heavy 5'ers have class 8 tow vehicles. Any danger towing with the Ram? Getting a 4.10 rear gear would allow 22K towing capacity.
Thanks!
I had a 2012 Ram 3500 Dually HO with 4:10 and GCWR was 29,000#, I think...They increased GCWR that year, but still old frame, only raised GVWR to 12,300.. Your pin weight could easily hit 4,000#, probably wouldn't exceed your trucks RAWR, but would go well over it's GVWR, (not widely used anymore)...I believe you'd be pushing the safety limits of your truck, but just my opinion. With the 3:73, GCWR is all the way down to 21,000#, you'd HAVE to change gearing, or loaded the way you are right now, you'd be around 27,000# (and that's going by your dry weight of 19,000#), so you would be approx. 6,000# over your trucks GCWR set up the way it is now.
As far as carrying "only 200#" of cargo....not going to happen. With clothes, pot's pans, dry goods, even with all tanks empty, you'll easily load more than 200#...
The trucks engine and tranny will handle it, no problem, BUT the trucks GCWR will be exceeded by quite a bit unless you opt for the 4:10 gearing, but still might be pushing the limits of the trucks RAWR....My 2012 empty weighed approx. 3500#, plus 3400# pin weight, at 6900#, so under RAWR and GCWR.....your pin weight, I would wager would be closer to 4,000-4100#...4:10 gearing might make it work...
Is the RAWR of the 11 9,000#?? I'm not sure, I know on my 13' it's 9,750# (rated to 11,500#)
About Fifth Wheel Group
