Cummins12V98
May 01, 2018Explorer III
ford truck guy wrote:Cummins12V98 wrote:MarkTwain wrote:
Leveling jacks---
Go to camping world and buy a "Travel aide". Approx. $60 from my memory. You just roll the RV onto the. Travel Aide and it will raise the tire off the ground enough to change it. Safer and no stress on the frame or hydrolic systems.
TrailerAid Plus works GREAT!!! I now have 6 point leveling. Depending on conditions I may still use the TrailerAid. General maintenance I simply place in manual mode and raise one side at a time. I have raised one side just enough or both off the ground.
Have you tried using that with the IS ?? I did, and could not get enough height.. I did not have any boards to place under it to get it higher though, Since the IS has 5-1/2" of travel..
I have not tried it. I probably should try it so i know what I would need. I have several wood blocks so it should not be a problem.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
